Driver Mirror adjuster popped
PeterKathy
Post by PeterKathy » Tue 21 May, 2019 8:32 pm
:dontknow:
I went to adjust my drver side mirror on my w124 300e 24. Heard a clunk....
Now no more adjustable. :pale:
Can still move by hand with the window diwn!
Any suggestions?
Peter and Kathy
brette013
Re: Driver Mirror adjuster popped
Post by brette013 » Tue 04 Jun, 2019 11:58 pm
Probably you broke the control arm that does the mirror adjustment. Should look like this with handle off and unattached:
You'd still be able to manually move the mirror by touching it even if lever mechanism is broke.
To fix you could buy another mirror 2nd hand and gently pry off the old outer moulding onto the replacement, then refit. Or if your feeling lucky, take yours apart and fit a replacement control arm.
brette013
