My Drivers door window and RV mirror stopped working. The CL is not affected.
This all happened at the same time and all other doors work correctly.
Any ideas where to start?
I am reluctant to remove the door card as the clips are likely to disintegrate when removed.
Drivers door electric issues
- Tony From West Oz
- OZBENZ moderator
- Region: Victoria
'86 W124 300D sold
'99 W202 C250 Turbodiesel
'98 W202 C250 Turbodiesel
'86 W124 300D sold
- T-Modell
- die Nützlichkeit Meister
- Model you own: w107
- Region: EU- Western
Re: Drivers door electric issues
Hi Tony,
first the fuse incl. their contacts (rust?). Then check the switches (cables, contacts). If all that is ok ... well then I guess you have to remove the door panels to see the wires/connectors/motor etc.
If you remove the switches, try to connect another switch to this door ... the old joke "What does a Siemens Technician do, when he has a flat tyre? ... He swaps it to the other side and checks if the fault moves with it" ...
- Region: Victoria
For a few bucks on ebay, you can buy a kit that contain door card removal tools there are also kits that contain both audio and door card removal tools.
like these : http://www.ebay.com.au/itm/4-X-Pry-Kits ... Sww9xZCZl5
or this : http://www.ebay.com.au/itm/Car-Door-Pan ... SwcUBYUL4f
Current
S212 - E350 Wagon
W213 - E220d
S212 - E350 Wagon
W213 - E220d
- Tony From West Oz
- OZBENZ moderator
- Region: Victoria
'86 W124 300D sold
'86 W124 300D sold
- Tony From West Oz
- OZBENZ moderator
- Region: Victoria
Fuse replaced by mechanic during GP work fixed the problem
'86 W124 300D sold
'86 W124 300D sold
